Hello,
A friend of mine would like to produce a documentary to be shown on the Internet or through a video projector during events.
He's no geek, but is motivated enough by this project to learn just enough about hardware + software.
So, he would need…
- a video recorder very simple to use, good enough to record videos inside and outside, sometimes holding the device with one hand while riding a bicycle, and that can take an external mike when interviewing people and avoid wind/noise
- a simple Windows application for editing
- at an affordable price, since it won't be used often and not for professional use
What kind of hardware and software would you recommend ?
Camcorder? DSLR? Accessorized smartphone?
As a reference, for the microphone, I bought a Boya BY-M1 which sounds pretty good when recording podcasts.
Thank you.
There are people that shoot a complete documentary with smartphones.
https://9to5mac.com/2015/09/25/iphone-6s-plus-4k-film-documentary/
Google for "documentary shot smartphone" and you'll see blogs and tutorials about the gear you need, for editing Blackmagic Davinci Resolve, it's free. -
Thank you.
I was thinking of a camcorder because I figure it'd be easier to hold with one hand, but there might be add-ons that do this too. -
You might look into a handheld smartphone gimbal. The electronic versions aren't cheap, but the stabilized image is worth it.
A similar, cheaper mechanical device may work also for a camera or phone.
Amateur Documentary Audio Editing
By Querorz in forum EditingReplies: 6Last Post: 10th Apr 2017, 09:15 -
Hardware and Software Purchasing Help Needed for New Project
By OriginalEGG in forum Newbie / General discussionsReplies: 13Last Post: 17th Dec 2015, 19:15 -
Going 4K for the serious amateur
By newpball in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 87Last Post: 2nd Aug 2015, 23:45 -
PC capture hardware / software recommendations
By MoreQsThanAs in forum Capturing and VCRReplies: 14Last Post: 16th May 2014, 11:16 -
Steaming Setup Help (Hardware/Software
By LouP9086 in forum Video Streaming DownloadingReplies: 2Last Post: 11th Feb 2014, 12:29
